Oil filter housing question
partylikeits82
82
May 9, 2009
Iron Ridge, Wisconsin
The ass hat that had my car before me somehow managed to strip all of the threads off of the oil filter stud. So i thought to myself "hey, ill just buy another oil filter housing, and ill be good to go". I ended up buying this housing EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Oil Filter Bracket Assembly: Mitsubishi Eclipse 06/90' - 04/92' along with the housing, i bought a stud for it EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Engine Oil Filter Bracket Stud for Oil Filter: Mitsubishi Eclipse 90-99
Lo and behold, this stud is the longer one that was intended to go through the liquid cooled sandwich plate. Does anyone know where i can get the shorter stud? Or am I going to have to get a different housing?
hey buddy. my sugestion to you would either be to go to any hardware store and ask them and or get an oil filter relocation kit off ebay. i hoped i helped. thanks
I would recommend you to insert a straight wire into the hole and measure how deep the hole is, and get the bolt on any hardware or any auto parts.
Bolt size is 8mm x 1.25
That's the thickness and thread size, so you just figure how long you need it.
I'm assuming based on his links, he needs the hollow ~1in hollow stud the oil filter screws onto. not an m8 bolt. It is late, and I could be mistaken though
I looked around online, and in my ware-house off a basement thats full of parts and I don't have any short ones, nor can I find them for sale on the interweb.
Other ideas include looking for one for a evo, or 3000gt. or calling satan and seeing what they can do..
And your car in your is a 2g in your profile, and you bought a bracket ass. for a 6bolt. I'd assume this is intentional(swapped a 6bolt, diff. car), right? and why arent you using a oil cooler plate?
And the last tidbit I have is you can buy a forward facing oil filter housing for the 6 bolts if nothing else works out.
http://jnztuning.net/shop/catalog/product_info.php?name=Forward%20facing%20oil%20filter%20housing-%206%20bolt&products_id=197
I was told by the previous owner that it is a 6 bolt, although the guy didn't seem to know a whole lot about it. I haven't had a chance to check the flywheel yet to make sure. It appears to be a 6 bolt motor, but it is a 95, so i suppose it could be an early 7 bolt. The car doesn't have a cooler plate, it has an external oil cooler. Would it be cheapest to just buy a cooler plate?
It would be easiest to call mitsu, tell them you need the oil filter stud for a early 1990 eclipse.
Secondly would be to use the cooler sandwich for a spacer, left unhooked, if it will fit on your oil filter housing.
clean him up real nice , maybe put him in a suit. Maybe we can get partylikeits82 to buy him ROFLROFLROFL
He better be good under pressure though! :p
Haha, I suppose i could use a wingman. Maybe its for the best that he's not a stud, he'll make me look better. ROFL
