1G OFH 90?
ariman
127
Jun 2, 2011
CA, California
Hi.
I want to know if this OFH is 90 turbo or n/a?, this OFH no has hole for Oil pressure gauge sending unit, now if it's n/a, i can use it in my 6 bolt turbo? and where can i put the Oil pressure gauge sending unit?
thank
What I got in my Laser is a JDM VR4 with the oil pressure sending unit mounted in front and no port for the idiot sending unit.
Thus, I do pressure gauge only. I've been tossing around doing the "T" fitting that was posted in those links so I can do both readings.
Ya, the pinched off lines are connections running to the front mounted air oil cooler that only resides on the 1990 turbo models.
