2G OE Rear Brake Assembly Replacement
drthorp
5+ Year Contributor
75
35
Oct 22, 2019
Trussville, Alabama
So I have been trying to replace the OE brake assembly on the back of my '96 gsx. I have everything together now and have yet to flush/bleed everything when I notice the original brake line (the rubber soft ones) are not mating flush with the new calipers... I ordered the powerstop rear brake kit from rock auto(link). Im wondering if I need to grab the powerstop steel lines for $118 since its a powerstop kit, but If it doesn't leak its fine right?https://www.rockauto.com/en/moreinfo.php?pk=7484552&cc=1205806&jsn=2147
Like when tightening the line to the caliper it doesn't thread all the way in. It is tight and I haven't detected a leak yet, I was just curious is this could pose an issue. I believe there are like two exposed threads on the line so it is basically half of the way in the caliper.
Ill post some pictures when I get home. Still no leaks and good pedal feel... thanks guys.
Rear brake lines have tapered fittings like AN fittings & there are no crush washers. Same with the Brake Master connection, proportioning valve, & the connection of the rubber lines to the body hardlines. You use crush washers with the front lines banjo fittings.
