2G 2G GSX rear hub assembly
Bedicine
542
192
Jan 3, 2022
Toronto, ON, Canada
Hello
Does anyone know if the rear assemblies have different part numbers for the passenger and drivers side? I’m having a hard time finding the full assembly and not just the bearing by itself. The ones I’ve found only seem to show one part number but don’t want to run the risk and order two if they won’t work.
Thank you
They are the same. Go to STM’s website and search for them. There you will find OEM 2g dsm wheel bearings. You will also notice that they are a little expensive. However you will also find the oem part number and the fact they are the same for certain EVOs. I used this information and found ones more affordable online elsewhere.
-Daniel
-Daniel
Thanks Dan. I as able to find them on Rockauto with your advice.
appreciate it
