2G ?? Torque for 32mm nut on rear hub assembly
dustyboner
DSM Wiseman
1,941
1,126
Mar 13, 2016
abq, New Mexico
New stud and new bearing put on. Started to tighten down 32mm nut and realized i have no idea what to torque it to. Of course there are no torque specs of in the FSM cause OEM replacements are the complete hub assembly.
if i had go guess id say 120 ft/lbs, just because it was harder to break loose than a lugnut but easier than the axle nut on the CV.
I haven't needed to address this on my FWD. Looks like the nut is 32mm like the the drive axle nuts. I'd just use the same torque spec. Would probably be about right. Spec is 145-188 ft-lbs.
