turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
I noticed my clutch was losing a little fluid every week and i KNOW the slave was replaced less than 2 months ago and the master was new in november last year (so 3 months on that at this point) and the ine is solid. I suspected crush washers so i changed them at the slave and now i can't get it blead or adjusted enough to shift good from a 1-2 at high RPm's to save me.
before just changing these washers it shifter perfect at 7500 RPM from first to second, now no matter how much I bleed it and re-bleed it and adjust it i can't get the same release i was getting before i fixed the leak (and htere's not a new leak at all) I just changed the crush washers on the banjo bolt at the trans and re-installed it, blead almost a quart of fluid through it and "thought" it was fine and one day on th way home it all the sudden would release barely enough to drive, so i get it the short drive home and bleed it again and it's still not perfect so i adjust some more at the master cylinder rod to where it's maxed out (1/2 turn from relief valve) and stll although i can drive it and it won't grind on upshifts it will "notch" on downshift into third/second, but won't shift wuickly at all, even thought it's not grinding i have to wait a horrible 2-3 seconds for the 1-2 shift and the 2-3 shift is about a second, but only a day before it would shift as good a s a rebuilt stock trans can shift
the feel doesn't change like an air bubble would make it do and i'm using more adjustment than before and all i've done is fix leaks and put in more and more fluid via bleeding it
any ideas anyone? there's great travel at the clutch fork as well, i'm just lost on this because it's done this before.. one day shifting sucks and i mess with the fluid and it's perfect, next time i mess wth it i can't get it right to save me
) we got all the air out and found that the main issue is the upper bushing in the clutch pedal where it pivots is shot, letting the pedal walk sideways a few inches and hit a yet bigger lump in the floor costing me over 4 inches of travel.. I need to drop it out of htere and machine some brass ones ASAP and i'll have all the cluutch i can ask for back again... When i move the pedal to where it doesn't hit the lump and travels fully there's not a click, grind or notch to be felt or heard, but whenit hits the carpet its like i'm just barely engaging off the "new floor" so to speak.. anyway it will get me back to the karmann ghia dash i'm wiring today to earn my living and this weekend i can possibly machine the new bushings for it as well as re-enforce the pedal arm so it doens't shift (with my bad left leg i probably helped this thing wear out like this but at least it's something i can fix, and with it fixed i can tell it's going to be a lot nicers to my poor old back and left robo-leg
