o2 dump problems
mikh338
163
Sep 3, 2007
niskayuna, New York
hey guys
so im having an issue with my PR o2 housing dump. i have the PR short route fmic and the dump tube was hitting the lower intercooler pipe. so for a temp fix i cut the dump pipe down a little bit and bought some cheap flex pipe to route it away from the ic pipe. has anyone ran into this same problem and what have you done. i am a very good welder so that is not a problem im just looking for some ideas. thanks guys
mike
I can't tell exactly, but try and play/adjust/ with the dump and IC pipe as muchas you can. A lot of times when I removed mine and put it back later, I am amazed what a short movement here and there, makes ahuge difference in position of dump tube, lowre IC pipe and clearance to DP or oil filter.
yeah its really tight spot and I do not want any hot exaust gases blowing on that lower IC pipe does any1 have any pics of what they did?
