420A no spark from any cylinder
reign 1
Dec 23, 2010
milton, Delaware
I changed my head gasket, now after putting my motor back together . It isn't getting spark from any of the plugs
I checked all connections to the coil, they are good. could the coil go bad just sitting on my work bench for the time it took to change my gaskets?
^+1
Checkk your coil, plugs and wires. If you have not gotten new plugs and wires you may want to think about it. They usually dont set you back too much. If you do get plugs, make sure that they are correctly gapped. Also MAKE SURE YOU HAVE GOOD CONNECTIONS. I can't stress that enough. I have read too many posts about a misfire or something to that affect and all because the connection was bad. But if you are not getting spark to ANY of the plugs, I'd lean towards coil.
Its very well so it could have. If you have the use of a multi meter, check the connection between the two prongs, the resistance should be somewhere between .51-.61 ohms or somewhere of the sort.
I can't remember what it is called for the life of me, maybe the transistor or somesh!t. Can't remember. But it's kind of off to the side bolted to the intake manifold under the coil pack if I remember right, black thing that is fairly thin. Make sure it's plugged in. If it's not you won't have spark.
^Good idea. Considering you had the head off, you may have unplugged it. And if that is plugged in and you still aren't getting spark. I'd say the coil
But like kstoopsdsm said, checking it would be your absolute best bet. If you are unsure of how to test coil, I'm sure there is a tutorial on it
i have a 2.0 nonturbo, where should i look for this connection? how many wires are on this connection? i did unplug alot of stuff.
