Seamus
- 589
- 40
- Nov 18, 2002
Eureka,
Missouri
So my harmonic balancer broke and i replaced it. During the replacement the crank pulley DID NOT turn counter clockwise even 1 degree. Car will not start now-no spark. Every relevant sensor checks out and ECU looks good. All fuses are fine. Anyone got any idea where else to look or what to check? Thanks in advance for oyur help.
ohh a little more background, I replaced the pump and regulator with a walboro and aeromotive AFPR also today then i did the harmonic balancer, so fuel pressure shows 20 psi while cranking wiht vacuum connected. Idon't think this is an issue though, and obviously is not causing the no spark situation.
