meekial
- 0
- Jan 13, 2011
bloomer,
Wisconsin
Hey everyone, I am having more trouble with my car...... again
. When I start it up it will either idle normally or run like it has a "miss". Then if it runs normally it will only last for a minute or two then die because of a "miss". It also blows black exhaust. It is clean when it idles normally.
I have my timing set at 5 degrees advance.
My fuel pressure regulator is at 42-43 psi at idle with my walboro 255.
My o2 senser IS plugged in.
My tps IS plugged in.
My battery was unplugged from my car for two days, could this have erased my tune on my ecu?
Could my FC 750's injectors be bad?
. When I start it up it will either idle normally or run like it has a "miss". Then if it runs normally it will only last for a minute or two then die because of a "miss". It also blows black exhaust. It is clean when it idles normally.I have my timing set at 5 degrees advance.
Make sense?
