420A Noticed power steering fluid under car.
pdodson18
47
Apr 3, 2025
carrollton, Georgia
This seal isn’t tight and is leaking fluid. Does anyone have a part number for it? Passenger side wheel. I thought there was supposed to be a boot there but I’m not sure. And would I have to take the whole rack out to replace it?
Yes, there should be a bellows boot there. Check your inner tie rod for excessive play now that it has been exposed to the elements.
To fix the leak, you need to remove the rack and rebuild it or replace it. IIRC, there's no way to access that seal without fully disassembling the rack.
Wowww okay good thing I noticed that. Thanks for the reply
any DIY? thanks
