no oil to the head ????/
tw21987tsi
Nov 21, 2006
fall river , Massachusetts
well here is my problem i have a 90 talon tsi new motor top to bottem i just started having a problem blowing up turbos and now i know why i had little oil geting to my head and no for some strange reason i have no oil getting to my head and blew yet another turbo i pulled the valve cover and started the car thats how i know no oil is geting to the head and yet i have good oilpressuer to the gauge 80psi cold start 100psi at a rev i even checked the sprederblock on the head to see if it was blocked and it was clear anolg with the oil filter oil filter houssing and oilgallys in the head i have even pulled the head to check it with compressed air and all is clear please help
I have an idea, how about fixing your thread properly with grammar, puntuation and caps like you were already asked nicely in another thread yesterday. If it's too much trouble for you to follow simple forum rules, I'll be glad to come back and close the thread for you.
The head gets it's oil from a passage in the block.
If the motor was running for awhile before this problem occured, some debris may have blocked this passage.
If the head was removed/installed recently, it may have been an incorrect gasket from the parts store, or as BISHILVR stated it may have been installed upside down.
Now that the head is off, you can spin the oil pump with a cordless drill (No air tools!!!), and oil should flow from the feed passage in the block.
  • Wanted 6 bolt NT water pipe
    • chrisman287
