2G NLTS Problems (ECMLINK V3)
Daimer
5
Jun 23, 2016
Grand Rapids, Michigan
I can't seem to get my NLTS to work. I installed the cable from ecmlink. I logged the clutchswitch on ecmlink. pedal not been pressed= 1, Pedal pressed in = 0. Clearly the switch is working. Now when I set my NLTS rpm point to lets say 5.5k, The car wont rev pass that point when I'm driving.no matter if I have the clutch in or not. if I disable it, car revs fine to my red line settings.
UPDATE!! so I logged both Clutch Switch and A/T D. Per ecmlink. A/T D should change from 1 to 0 if Cutch Cut is disabled and "CltchSw" should not change. That's working perfectly fine. Then when you select no lift to shift. "CltchSw" should be the one switching from 1 to 0 and A/T D should not change. Well When I enable it, both A/T D and CltchSw are changing from 1 to 0.
You have the wire connected to the switch that’s farthest from the firewall?
If that’s correct, try inverting the clutch switch in settings.
I’d recommend you lower the nlts rpm until you figure this out and you get used to it. It takes a minute to learn to keep the gas pedal floor’s 😁
