NLTS ecuflash
Some Older versions of Ceddy Mods use/used pin 91. But there was some problems with the logic the ECU used with extra maps because how many maps the Auto cars have or something along those lines IIRC... The newest 1.9Cb uses pin 44 though and that is what you should use more then likely.
Keep in mind you will need a clutch wire Like this to Use it wire to the Clutch-switch though.
Hope that helps :)
I have 1.9c complete, I have mine wired through the cruise control switch. black wire going to ground and black/red going straight to pin #44.(dont use cruise control anymore). Ill wire it though the clutch switch and see if that helps. My symptoms are the NLTS is acting like a rev limit when driving. WHEN THE CLUTCH IS NOT PUSHED IN. There's some threads of this but never a resolution. thank you.
Not sure off the Top of my head if 1.9c is on Pin 44. But I don't recommend using the CC switch it tends to set the NLTS off to soon and easy. As well you need a Real Clutch Cut wire for the NLTS to work right. Pretty Simple to make with a 4001 rectifier diode... .
