newbie needs help
extremeatheist
341
Apr 12, 2010
wilson, North Carolina
I bought a 95 420a eclipse disassembled.
I have no idea where this connector goes.
Any help is greatly appreciated.
Auto or manual? The ECU bolt right in front of the driver side strut tower. It bolts to a black carraige along with the TCU (if its an auto). The battery tray goes right to the left of the driver side strut tower. I cant rememver how it bolts to it, but if you look at the bolt holes on the tray and the bolt holes on the strut tower, you should be able to line them up and figure out how it goes. It should be held on by 12mm bolts. I hope his helps some.
Not the injector harness.
maybe this will help.
WTF k....hold on...
*EDIT* It plugs into a harness coming out from the loom underneath the intake manifold. I'm pretty sure that it is for the crank sensor but it might be a cluster harness for the knock sensor, too. Here's a pic for reference. You can see the fuel line with the metal jacket on the left and the shift cable sitting on top of the harness itself. :thumb:
