New HX-35 RECORD 10.71@133
WOW!, Yes, I think the fastest MPH is even more impressive than the 10.7 . . .But Just wow! not bad for a 54mm turbo! The 20g has a 53mm inducer!
There's a FWD 2g with an 8blade hx35 tailing you. Put your stuff in the ECMLink fastest times for this year. Your setup will fall in the top 20ish :).
Thanks and I have been keeping a close eye on him. It sucks that all the tracks are closed by me so all I can do is sit watch and wait. I havent been on the link forums in a while. Im going to go check that out.
So its going to be out with the 35 and in with the 52 for next season. But a close friends is buying the set-up so there is possibly better times to come but will see.
haha nice. I went 11.0@138 my last time out but no better ets. I just bought an hx40 tonight;)
how much you want for that 35? LOL im local
hah I remember you. Probably 350 since you're local. You know that this is the highest HP hx35 turbo;) Im thinking about getting the 40 rebuilt so I don't know when it will be off the car. What backhousing are you thinking about using?
If your going to switch to the 40 I would use your 35 frame. The 40 shafts are weaker then the 35s and more then a few have broken them. HTTURBO has an upgrade kit with a pro40 wheel I believe. Here check it out. High Tech Turbo
well I have all the parts needed to do that. Why would I want to spend the 300 on a compressor housing I have and a billet wheel I have unless there is something else I need....
Oh I didnt realize that you already had the parts. I thought that you were saying that you were going to buy and rebuild another. If you use a 35 center I believe it needs to be machined to accept the larger wheel.
ya I picked up a complete hx40 so Im gonna throw in on tomorrow morning probably.
why not go with the hx55 its similar to the 42 but spool faster according to the RX7 guys I have a 55 & the thing is massive. the 52 is a T6 setup
HX52's aren't necessarily all T6's. The one I have is in a 16cm divided T4 housing. The bolt pattern was just a bit off and I had to machine the housing bolt holes a tad but noting major and it's a near perfect gasket match.
Ahhh i cant wait to get the 35 on my car its gunna be a whole nother car with e85 in it too, not much longer tho.
Im as excited to get your car into the tens as I am to get this 52 setup together. Its going to be sweet.
Do you have an open center diff or is it welded?
A local 9-second 2G driver claims no wheel hop on street tires with his car, and one of his tips is to put cables from the front control arms to the body at the standard ride height to keep the front end from lifting too high during a launch. He also has open front, center, and rear differentials....claims it's the ticket to fewer broken driveline parts. ;)QUOTE]
umm where on the body could you attach the cables that would hold?? i would like to try this in the spring:pray:
