need thread for fuel pump rewire
Are you seriously, search.
There's a complete writeup for a 1g..............................
Basically, there's four wires to the fuel pump, ground the pump to chassis, power is from battery fused to 30a relay to the stock fuel pump wire.
Essencially the stock fuel pump power wire becomes the turn on for the larger gauge direct power wire.
Simple?
Most kits that you buy will have the instructions included... with pictures... at least mine did... took about 20 minutes... MAX. good luck
Ok im going to be a thread jacker.
just because
Will it help to put in a bigger pump, without the rewire?
If you're running out of fuel with the stock pump, then yes it will help to put in a bigger pump, even without a rewire. Will your new/bigger pump be working at its full potential? NO But it will (of course) be able to flow more than the stock pump.:)
search>search forums>enter keywords(fuel pump rewire)>choose either whole thread or title only to seach from and hit enter......then read;)
Hahah, I did. It brought up all kinds of stupid shit, some not even remotley related to the topic. Every since they redid the site, I have problems finding threads through searching.
