Tdbranch
- 0
- May 11, 2014
Van wert,
Ohio
I pulled my oil pan off of my g63b engine, thinking I had a rod knock. Checked all the bearings and they looked like they had normal wear for being 27 years old. I happened to glance at the drivers side and noticed the balance shaft was missing the big(rear) bearing. If the bore is out-of-round, am I screwed? Where does the oil pressure go thru? Any way i can cut the shaft off right behind the oil pump and plug the oil gallery?
How do the balance shaft delete kits work? Would this help me?
