Need some help Please.
gtrej01
406
22
Dec 13, 2010
Granger, Washington
Ok. I have a 1997 Eclipse Spyder Turbo.
I have the following mods:
Evo 3 Turbo
Turbo Back 3" Greddy Exhaust
Greddy FMIC
Greddy BOV
Perrin MBC
Boost gauge
I am in the process of eliminating the vacuum lines. I found 3 different setups and was wondering which setup is the correct one and or better on. Thanks for the help in advance.
I have attached the pics below of the diagrams I have found.
I currently set it up like the 3rd diagram and its is sputtering on me under boost. Please help?
Alright don't use your last diagram. I would use your top diagram. You can feed your boost gauge off your feed line for fuel pressure solenoid or off port P on your throttle body. After you delete your vacuum lines you must to a boost leak test.
The first diagram is the best setup. Everything should have its own source if possible. The only thing I would do different is source the boost gauge from the TB instead of tee'd into the FPR.
