Need help with clutch and flywheel torque doubt
JOBY_GST
46
Nov 9, 2012
Hormigueros, Puerto Rico
Hello guys
im in the process of installing the flywheel on my 6 bolt swapped engine, but i have a 2g transmission. my question is, do i torque the flywheel and clutch bolts at the 1g specifications or at the 2g specifications? assuming that they are different torque #s. and if so, how much is the torque # for both?
thanks in advance
They are the same. The Clutch is the same between 6 and 7 bolts, only the flywheel is different. 100 ft/lbs with red loctite for the flywheel and 14 ft/lbs for the pressure plate. Make sure you torque the PP down in a star sequence to keep from warping anything. You want the pressure as even as possible all the way around.
Do yourself a favor and check the flywheel step height. Make sure its .610" to .612". .612" is ideal.
Here's a bunch of other torque specs for the trans stuff:
http://www.dsmtalk.com/forums/showthread.php?t=192782
If you need torque specs for anything 2G related then download the PDF here
http://www.dsmtuners.com/threads/torque-specifications-specs-spec-nut-bolt.382492/
and once open press CTRL + F and type in what you're looking for. The ^ and v arrows next to the search bar allow you to scroll through results.
Thank you !
In what sequence should I torque my flywheel? And its 100ft/lbs from what I read
I would recommend a star pattern.
Torque spec. for the flywheel is (94-101) ft.-lbs.
