Clutch and Flywheel
GRace
147
Jan 25, 2011
Joplin, Missouri
I was told that this clutch was an ACT 2600 with some sort of special flywheel. Can anybody confirm if this is true by these pictures? There are no numbers on either the clutch or flywheel.
Its not a ACT clutch disk I can tell you that. The center hub is different.
The pressure plate is the correct color (yellow) for ACT. But IIRC my pp had ACT etched into it.
Flywheel looks like a lighter weight steel one.
The pressure plate is definitely an ACT. I don't see any reason why the seller would lie about it being an ACT 2600lb pressure plate, it's in great shape. The clutch disc is a ClutchNet unsprung six-puck disc. I'm not entirely sure about what brand the flywheel is but everything looks to be in great shape from the pictures. :)
Thanks! That's good to hear, I was worried about it because I didn't see any markings besides the Clutchnet sticker but it and the flywheel look brand new, the pictures just don't show it very well.
Glad I could help, that's what we're here for. :)
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
