Clutch and flywheel
99silvergsx-levi
Jun 16, 2016
Moorhead, Minnesota
I bought a clutch for my 99 gsx and it has and after market light weight flywheel and so the clutch doesn't work for it so how do I know what clutch to order for it with the after market stepped flywheel?
From the pictures the original one doesnt look like its stepped and so when I put the clutch in there with the alignment tool and mount the pressure plate and cover over and tighten it the clutch disc is still loose inside and will fall when the alignment tool is pulled out
Okay so I got that figured out and they had sent me the wrong clutch and so I got it all put back together did the 500 easy miles on the clutch and had done a few pulls in it and did another one and as soon as I went to shift from 2nd to 3 it shut off on my and now will not start. So I got it back to NY place cause my belts have been squeaking and so I was going to replace then the next day so I thought it was maybe the time belt but the timing belt is only missing like a 1/4 inch piece that's like a foot long on the belt. So what could be wrong?
The piece was still attached to the belt itself and when you turned it over it would just spin around all the sprockets could it still be possible?
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
