clutch and flywheel upgrade
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
I need a quick explanation of what the 7bolt fwd guys use for clutch and flywheels.
My goals are 350-400whp dailydriven....but I don't put alot of miles on ...I put 10,000 on in a year and 1/2.
I have about $660
1. clutch and pressure plate
2. flywheel
well if your going with act . you midess well get everything from them. fidanza flywheel i have heard good and bad. i heard that it sometimes gets loose. some bolt issue.
unless you havent upgraded your bearings i wouldnt recommend the act pressure plate it really strains them and might cause crankwalk.... although its usually a hit or miss some people can go for years with them and some just a couple miles.... your call tho.. i do like the act flywheel tho
I don't know how experienced you are with driving but i personal would recommend the ACT 2600 and the 6 puck disk its an excellent combo, but if you are not comfortable with the the stiffness in stop and go traffic i would say the ACT 2600 with the street disk or the 2100 /street disk. either one is suitable for your goals.
just went 11.60s on a spec stage 2+, a great clucth. i had drag issues with the 2600 act pp with ANY sprung disk, getting locked out of 2nd gear is very frustrating. My spec is very streetable., also look at south bend, there kevlar disks supposed to be even better then the spec one i have
South Bend Clutch SS-Series pressure plate with the TZ-Series kevlar full-face sprung clutch disk $435 plus fidanza flywheel at $190 for $625ish
Fidanza 2.1 Clutch for $288 plus fidanza pp for $480ish
stage 3 spec for $289 plus fidanza flywheel $480ish
ACT Xtreme (2600) Clutch Kit + Fidanza Flywheel for $619
The south bend SS series pp would be the best choise for the seven bolt motor and the TZ disk cant be beat. For your set up this would be the best clutch kit to go with. South bend makes some real nice high quality clutches.
that might be alittle out of my range when I come to think of it.
what about the fidanza or spec kits?
what would you guys ranks these in order?
Fidanza 3.2 Clutch for $352 plus fidanza pp for $540ish
what else would I need to get, besides the ss line and oem tob?
flywheel bolts?
fork?
pivot ball?
so should I go with the southbend ss series with the tz kevlar disk with fidanza flywheel for 625ish
or the the ACT heavy-duty Pressure Plate MB010 and ACT 6 puck solid race disc plus the fidanza flywheel for $580
is the sbc worth $45 more than the act
1. act
2. southbend
Well I'm trying to find some deals and I also wanna know what disk or plate I should not use for a 7 bolt.
Looking for 350-400 FWHP
1. I can get a act 2100, with F1 Racing 6 puck solid race disc and fidanza flywheel.
$485
2. Fidanza 3.2 with Fidanza flywheel for $550
3. some other option you may have under $600
I wanna get a fidanza flywheel so about $400 for the clutch kit or less.
I want the strongest pressure plate I can get without putting the 7bolt in danger, I would like to not get a clutch that the springs fall out, so either ones without them or ones that are good.
supports 350-400fwhp
thanks.
you can usually find used fidanza flywheels pretty cheap in the classifieds.. if you trust them that would be a good money saving rout.. and if needed in the future they sell replacement friction surfaces i believe
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
