clutch and flywheel
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
okay so I'm looking for a clutch kit that includes the flywheel and clutch, where do you guys get your kits?
I wanna go with an act clutch and I am looking for 350-400whp so will the 2100 cut it or should I go with the 2600. Also I have a 7 bolt so what are my options with not getting such a strong pressure plate?
looking for the disk without the springs in it that I hear fall out, what is this one called?
thanks.
I love my Act2600 clutch setup. I am running it with a 7bolt act light weight flywheel and a street organic clutch disk. Clutch pedal does not feel stiff. SS clutch line hose is a nice upgrade too. A little longer slave cylinder push rod may be needed. With an aluminum flywheel I would highly recomend a forced performance dsm aluminum flywheel hardware kit (please note that I had to shorten the flywheel bolts by about 2mm and balance each one after that because crankshaft holes were not deep enough and I did not want to drill/tap those holes deeper)
Forced Performance Turbochargers: DSM Aluminum Flywheel Hardware Kit
In AWD cars there is a side effect after clutch upgrade, it is a harmonic vibration noise which happens only while in a gear decelerating between around 3k and 2k rpm. Noise is more severe on those cars with stiff motor/transmission/rear-differential mounts. I searched many threads related to this side effect and found no real solution. I was able to partially mask the noise by replacing propeler shaft's pilot bearing mounting rubber bushings with solid aluminum bushings.
