Flywheel? Clutch? Problem Need Help
90_Talon_TSIAWD
Jan 25, 2006
Amityville, New York
I got my clutch done in like January or so and it a was slipping, it wouldnt go it would just rev, so i got it changed and the clutch i just got in like 3 weeks ago is starting to slip also, but it only does it when the car gets hot, but when the car is cold it drives good... I think its maybe its the Flywheel thats no good and is messing up my clutches... what do you guys think???:confused: :confused:
Thanks!
Did you have the flywheel resurfaced and stepped properly?
Was the pressure plate replaced or just the clutch disc?
What kind of clutch?
How much power are you putting out?
No i havent gotten anything done to the flywheel... Yeah the pressure plate was replaced along with the clutch disc... Im pushing about stock HP, all i have is BOV, 3'' exhaust from tha turbo back, and fuel pressure regulator... I got a stock clutch in it.... im thinkin of gettin a Racing Clutch and Fidanza Flywheel if my flywheel is no good....
