clutch, flywheel problem!!
2gTalonnn
55
May 27, 2009
SD, NB, Canada
ok so i really need help i just got a 1st gen gst with a performance clutch and flywheel. its extremely hard to get it in ANY gear and VERY hard to push the clutch down. it seems like its getting worse and worse. i narrowed it down though. when i turn the car off it goes in every gear with no problem. Now when its off and in gear lets say i push the clutch in nothing happens! if i really slam it to the ground it slightly rolls. so do i have to adjust it?? help please
He might need an extended clutch push rod. Some clutch kits need a longer arm to operate properly. Check that out first.
thanks for the responses but i fixed it i just adjusted the cylinder rod and it fixed it thanks guys.
