2G Need Help with build, stockton, ca
Mitro Z Nzongo
Jul 18, 2018
Stockton, California
Hi dsmtuners this is my first post so bare with me.
I have 1997 eclipse gst that i been working on as my project car lately, i gone thru motors and etc.
I had a spare motor that i decided to build. I got the block and head worked on at my local shop dynicron in stockton. The head has been machined for a mls head gasket so has the block. The head also had its valve guide replaced, all the valves have been measured and are in spec. Replaced the valve stems with supertech valve stems, and got the block honed. Crankshaft and camshaft bearings where also polished at this shop
+300-500hp Parts list:
Wisceo hd pistons
Manley rods
Kings bearings
Crower 265/265 cams
Stock Crank
Balance shaft delete(bearing installed by shop)
Cometic MLS headgaskit
ARP head studs
Walbro 255
1150FIC
Aem tru time cam gears
New oem gasket,seals, and belts
Now i been trying to find a shop to build my motor and nobody wants to do it with using there parts only. If you know a shop willing to assemble my motor that help(motor is 100% dissembled).
Im asking for help either some one can help me out and come thru and help me build it OR i can pay someone outright to build it for me.
If your intersted send me a private message thank you
Too bad I'm laid up and not visiting family, I'd come help you out it together otherwise, got family in Galt/Lodi.
Idk about any shops around there, did the shop that did the machining not offer assembly?
I am building 2 6 bolts right now and progress is not fast but meticulous for prep. If you have any questions, you can hit me up and I will help you thru as much as I can. I've only built motors for 40 yrs. Last 5 have been 4g63 and Saturn DOHC motors. Saturn just got to 10k this week. But its just nuts and bolts and checking specs.
Good luck!
They sent me to a previous employ, who he's willing to do it for $400. He never touched one of these motors so im not %100 sold o him yet.
Yes that is not something I'd recommend.
Maybe look at "RPM Speed Center", they came up in a quick Google search. Just make sure you're clear in communication, and ready to pay for services.
I'd recommend doing some research and assembling the engine yourself tbh.
If you lived in the area, Im always up for some building assistance, there has to be alot of Dsm guys out that way that would jump in, you just need to network to find that person.
Yeah make sure you send it to someone who builds dsms not just an engine shop only because timing a 4g requires specialty tools and another shop may not use these and mess something up like tension on the belt itself. You can assemble it yourself if you get every torque spec and you tighten in sequence but if your unsure send it to renowned dsm builder.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
