Need help wiring up slim fans, asap
chuckdog_5
1,338
Oct 23, 2002
San Diego, California
so its been awhile since ive been in the dsm realm, finally getting my car running but looks like the only thing stopping me are the slim fans. Previous owner just left the fans not hooked up and i cant remember what the stock fan plug looks like, im not the best at wiring so please help me out here. Just need to know what goes where
so i wired up the fans and hooked up the fans to the geen wire. Wich turns on the relay but the fans wont come on at all? what am i missing here?
See this tech article
http://www.dsmtuners.com/forums/articles-electrical-wiring/345217-slim-fan-wiring-relay.html
If anyone can edit this pic to show a dual fan setup in parallel that would be cool too :)
When I wired up to the green wire the fans wouldn't come
on, but then I realized i don't have the lower temp sensor in the radiator. How can I make up for tht if it's MIA?
You can just put a jumper wire in the plugin that goes to the sensor in the radiator, and the passenger side fan will run whenever the key is on.
You can use a plugin off a stock fan to wire up to the slim fan, or just off cut the plugin and wire it up. Just note which wire goes where, as the fan will run backwards if the wires are hooked up backwards.
That's alot of wiring for someone not confident in their wiring at all, I can't find any of the normal stock plug ins, I don't know what this guy was trying to do. From the pics I posted those are the only plug ins not connected to anything, I'm just trying to find an alternate place to wire in the power.
