NEED HELP can my CAS be 180 out of alignment
TheRealist
464
3
Dec 12, 2005
Chula Vista, California
Guys we bin trying to get my car started we have but it still seems like the timeing is off a bit, but how would you check to see if the CAS is aligned right?
Open up your cas (intake cam opposite of the timing belt side), 3 10mm bolts holding it on, take a 12mm socket and take out the bolt that attaches it to the cam. Flip the cas 180 degrees and put the bolt back in. Replace the cover and start.
Hope it helps
