1G Need help - 3 PLUG EVO 8 ECU in 1G
Marcel
3
Dec 7, 2014
Kraków, Poland, Europe
Hi guys,
I am trying to wire what appears to be 3 PLUG EVO 8 MR ECU (MN132750) in 1GB AWD DSM.
My post count won't let me replay to Spooligan's fourgsixthree33 thread.
I've created a excel spreadsheet using info I gathered online, but I am not sure if all pins are matched correctly.
I will be more then happy if someone could take a look at the spreadsheet and chime in with any suggestion.
Thank You in advance.
I have never heard of our seen a 3 plug Evo VIII ECU before. Are you sure it's not an Evo III ECU or something? I am pretty sure all Evo VIII ECU's have 4 plugs.
My SPOOLIGAN's Evo ECU In 1G Documentation thread doesn't have all the information because DSMtuners won't let you edit the original post after X amount of time. See my write up on my person website for all the info- http://dev.eatsleepdsmmag.com/index.php/2016/02/25/using-an-evo-83g-eclipse-ecu-in-a-dsm/
Thank You guys for all the support.
Yes, I am sure it's a Evo 8 ECU, part number is MN132750 and I believe it's either JDM or EDM Evo 8 ECU.
Almost all information that I am using is from Your post and website as well as dsmecu forums.
I managed to confirm some pins, but still need to figure out MPI related pins.
