TasosEclipse
- 118
- 4
- Oct 20, 2016
Thiva,
Europe
can anyone tell me if I can run my evo 3 engine with a 1g ecu ecmlink
Doesn't matter if it's free if it won't work.To find a 2g ecu here in Greece is very difficult. And my friend has a ecmlink full chip for 1g and he will give me for free.
How do you intend to get the engine to fit in your n/t?
That isn't what I meant. It won't work because it's completely different, the plugs are different and it uses a different OBD setup. 2g may be harder to find but you'll have a better time if you do this instead of trying what you're stating. Can it be done? Yes. Should you try it? No.No it works I’m sure he had it in his car
Wait a minute you already have ECM link? You post about it earlier this year also. What is it that you're trying to do? If you just need to upgrade ecmlink then purchase the upgrade. It sounds like you have the light version and you want the full version.I have a gtx3071 I am running 1.5bar for the last year and I have no problem I tuned it my self with ecmlink but I want all the other features. Thanks for your replays
