- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- SS braided oil feed and return lines, Evo III 16G, Greddy FMIC with piping, Greddy BOV, Turbosmart MBC, Walbro 255lph fuel pump, Aeromotive AFPR, FIC 1600cc injectors, Oil catch can, PS delete, AC delete, Emissions delete, NGK br7es spark plugs, NGK plug wires, 1G CAS, Aluminum racing radiator with 2 slim fans, Tubular o2 housing with dump tube
Custom front exit exhaust, Aluminum intake pipe, Cone Air filter
- Mods-Engine
- ARP head studs, BC 272's, BC valve springs, head ported, BSEK.
- Mods-EMS & Logging
- ECUflash, Evoscan, black box ECU, Innovate LC1 wideband, boost/oil PSI/water temp gauges.
- Mods-Drivetrain
- ACT 2600 Clutch, Fidanza aluminum flywheel, LSD rear.
- Mods-Handling
- Camber kit, Megan Racing lowering springs, Moteggi 18" wheels,
21mm wheel spacers, ABS Delete with SS braided front brake lines, master cylinder to caliper
