need clutch switch help
beihl304
286
Jun 7, 2008
mcmechen, West Virginia
well i happened to cut the green wire that went to my clutch position switch thinking it was what i need to cut but then i realized that i needed a wire from the cruise switch. now, since the wire is in a tight spot, i can not connect the wire back together and the car will not start till i do. i was hoping some one would know where i find a wiring diagram so i can see where the wire goes and just rewire the switch. or is there a way i can just delete the swtich completly so i can start my car? thanks
Pull the theft alarm starter relay out and then cutting that green-black wire (which goes to the starter relay) will allow the car to start.
Note: The starter relay is normally closed so disabling it allows starting. Also the cruise wire (black-red) is on a separate part of that switch (actually is 2 switches with separate connectors).
