Need AWD manual transmission outer diagram
latkins09
118
Nov 3, 2012
stockton, California
I have a bare awd trans and need to install all the components I.e slave cylinder, mounts , shift brackets. Does any one know where I can get pictures or a diagram of the trans. It's for a 2g
Here is the exploded diagram from the ASA software:
Hello,
you can help me, I need to know the number of the part 21117 in the previous diagram. you know somewhere where you can get a diagram with each part number? I am restoring a 1g AWD and need many parts, I appreciate it
You need the part number for the 5th gear cover?? The only one that is still available is MD741184 for the large diameter 5th/reverse synchro assembly with the steel shift fork. The early version is no longer available.
The inside of your 5th gear cover will tell you the part number you have as it is stamped inside.
Ok thanks, today I will observe that number, then I need the diagram of the entire front suspension with the part number, I find that repairing a 1G GSX suffered a collision.
I need a lot of help
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
