need a stock 2g fuel pump
dcmarf
101
Aug 1, 2010
Theodore, Alabama
I have a 95 gst that sat for 3 years it needs a new fuel pump and I gotta go stock since car is all stock. Where could I find one? Also, I broke the housing on the top where the hard line hooks up (should have disconnected it under the car not on top of the pump housing my bad) Ill look in a junk yard for a new housing and the tank is full of rust -Should i clean it or have a radiator shop do it -Im not sure how to clean it all out -There is alot of rust in there.
I don't know where to find a stock fuel pump but you had better get something else. The stock fuel pumps are denso hunks of junk. They can hardly keep up with the motor at factory stock. but as far as cleaning the fuel tank out i have cleaned out a few tanks on motor cycles with just diluted muriatic acid. then wash it out really good with water. I also know that its a good idea to use a good (chemically resistant rustolium black primer from AZ works for me) primer that you can spray inside to stop the rust from coming back. I have never don't this to a car though so be careful. That's all i know about cleaning out tanks just because it works for a bike doesn't mean that it will work for a car. Its just an idea if you want to try it.
Nope, the 255 will though.
no you won't! been on a 255 all summer with stock fpr. Might have something to do with that fact that i'm e85 but yeah.
I'm pretty sure i have my stock one if you want it pm me i'll let it go cheap!
as for the top good luck most junk yards have to remove the fuel systems you might get lucky tho. as around or go to the mitsu dealer(or any import dealer honda toyota ect...)
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
