stock fuel pump
ChrisFlo
412
Aug 29, 2004
Tucson, Arizona
Hey guys, takin the 2g gst back to stock and upon finding my stock fuel pump again, noticed the o-ring and plastic tip (like what came with the walbro 190) were not on the pump. Are they supposed to be? I know I didn't transfer them to the walbro pump. It's been so long since I looked at a 2g pump that I don't even remember if they're supposed to be on there. Thanks.
All that gives me is info on aftermarket pumps, which is not what I'm asking about. Besides, is it really easier for you to type in "vfaq.com" than "Yes" or "No"?
Yes it is supposed to have the oring and spacer stock. The best thing to do is just forget about those pieces and replace them with a short section of 3/8" fuel line. It will fit the top of the pump tight and will also fit tight in the bell of the pickup assembly very tight. No clamps required, cheaper than stock parts, and seals better than stock parts. The piece of hose needed will be about 1" long.
  • Wanted 6 bolt NT water pipe
    • chrisman287
