n/t rods and pistons
now i am ok with a 6 bolt n/t and n/t pistons with a 14b with 10psi?
i only have 90k miles on the car
It has been said that if tuned properly, you should get by with n/t pistons up to 9psi. You do understand why they are not ideal though as has been explained?
I assume you'll be switching to a 1g Turbo ECU? If so, find yourself an EPROM one and order ECMlink.
Or if you want a cheaper option you can get on the Yahoo! DSM-ECU group and learn how to do EPROM editing. That could potentially do just as many things as ECMlink.
3" GM Maf and Translator
SAFC
DSMAP
Full stand-alone (AEM EMS, etc.)
All very good options... You must search though...
Nope.
Autos are different because of the smaller injectors and higher base fuel pressure they run. But if you burn your own chips you can fix this.
    • george bromwell
    • pma1123
    • Sdcryan1
