gofer
Moderator
- 8,165
- 1,556
- Feb 18, 2006
South Gilbert,
Arizona
Can you overlay that with your logs in ECMLink too?
What a dream build...
Forgive my laziness and not combing through the whole thread... Do you run a trans cooler?
The shorter third and fourth gears did make a difference and I started running out of gear in some spots, getting a little closer to redline than I'd like (for this stock motor). I played around with shifting in some different spots than I'm used to but never quite landed on what I think worked best. I think the gears are still sufficient for a balls-out run approaching redline, but for lapping twenty minutes at a time I don't go balls-out like that every lap.
I had to get a new manifold and it's on its way to Detective Coating now for ceramic coating.
This was my first real project that I got to use the welder. I've become pretty reliant on Solidworks for design work.
Nice duct work on that cooler! Its tricky getting it to taper well and work right. I rusbed mine in 1 day for 2 coolers but yours looks soo much nicer and i like the take off for the PS cooler also. Is the back venting now you have all this air directed to it? Or even a plate at the back pusbing it down under?
Nice update on the car man.
Interesting thing on the brake pads! Why did he say go 16? He suggested to me keeping my 10's. I always wonder why the same chassis is told different outcomes from the same person. Could it be your more full weight or alot more power?
My car is 3000 lbs, maybe around 350-400 hp. Brian's is around 2650 I think with probably 300 hp. I have the XP10's in the rear and have been happy with the 10/12 combo, but time to try something more aggressive in the front.I just wanted to chime in and say I appreciate every second of time you spent with safety wiring bolts. Not sure if Brian told you, but I had bolts coming undone during really short easy shake down laps; I imagine at full tilt it would get pretty spicy. I know you know, but definitely worth the time it took for you to drill and wire. Great update; hopefully your track day remains open during this crazy time!
p.s. Nice welding machine!
That's a long time coming, I remember you and Craig making SolidWorks rendering showing strain tests/drawings 8+ years ago.
Found it! Sorry, Brian, for not giving you credit too.Good memory!
Metal Front Bumper Tow Hook MountFound it! Sorry, Brian, for not giving you credit too.Metal Front Bumper Tow Hook Mount
Really like what you two came up with this time around, hopefully you never have to test the theory in the real world though.
(I fixed it for you.)
