2G My clutch *pops* :S Help
project95talon
49
Jun 14, 2004
Sudbury,
Ok, I've done a search and I'm guessing it could be MC or the spring? Every few times I engage my clutch pedal it makes a popping sound and I can feel a clicking in my foot? Anyone care to explain what is going on. Thanks a bunch, my problems just never end. Everytime I look into spending money on upgrading the car, this happends...
Its just like bleeding brakes. theres a bleeder screw on the slave cylinder that you just unscrew and hook up a suction tool to. im thinking its a 10mm flare that you need but im not 100%. make sure you keep the reservoir full the whole time or you will have to do it over. just use normal dot 3 brake fluid in it.
i am not positive but i wouldnt reccomend just pushing the clutch in to bleed the fluid out. i have never done it this way so im not sure how well it works, but if you have access to one of the suction tools for bleeding brakes id just use that.
Is it a popping noise or more like a clicking noise? If it's just a clicking noise when you engage/disengage the clutch pedal, it could very well just be one of the clutch switches underneath the dash. I think it's the cruise control switch that clicks..?
I had the exact same problem, along with some creaking when I depressed and let off mine. However, mine sporadically went away for some reason :confused:
