help changing my clutch
TeclipseFTW
193
Jan 12, 2009
Lees Summit, Missouri
Hi my clutch went bad and it barely disengages when I depress the clutch so... I need to replace it all. no it isnt a problem with the hydraulic clutch system it is the actual clutch assembly (probably my throw out bearing)
My question: I moved out of my parents place and now I have limited tools and no garage. I will be changing my clutch in the parking lot of my apartment complex and I need to know every tool I will need to do this job. I have done it twice before I just need a list so I can make sure I have the tools before I start this job so that I can complete it asap.
Thanks!
This is a pretty rough list but should get you started in the right direction :):
- Jack and jack stands
- Lug nut key and/or socket size for lug nuts with torque wrench
- 32mm socket or wrench with breaker bar for axle nuts (or impact wrench)
- Pliers for cotter pins on axle nut and shifter cables
- Drain pan for transmission fluid
- New transmission fluid (unless you're reusing the fluid)
- Socket for transmission drain plug (24mm?)
- 3/8" socket set with ratcheting wrench - 10mm to 19mm
- Assorted wrenches - 12mm to 17mm
- Adjustable wrench might be useful as well
- Pry bars and long/strong flat head screwdriver for prying axles out of the transmission
- Rubber mallet and/or dead blow hammer for stubborn bolts and axles
- Clutch alignment tool
- Loctite for pressure plate bolts
Edit - Added:
- A friend to help you reinstall the transmission or a transmission jack
- Plyers for cotter pins on axle nut and shifter cables
I think that covers it... I certainly don't envy you having to do this in an apartment parking space :(
A tranny jack is the way to go try to line it up how u want then jack it straight up going in in a awkward postion is going to P you off believe me made that mistake.
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
