bad, changing clutch engagement
KillaB_TSI
May 5, 2004
Oak Harbor, Washington
I have a 95 talon awd. I've been having a problem with my clutch engagement. My simptoms are the following, my engagment points on the clutch peddle differ while I'm driving some times the engagement is at the top of the peddle and some times it's right where it should be in the center of the clutch. It comes more to the top of the peddle when I drive on the interstate and hit boost. I'm running an aftermarket act 2100 clutch kit with street disk and flywheel. I've blead the clutch twice so I know that there is no air in the system. I checked all the lines and there are no leaks, and the fluid is allways full. I'm thinking it's possably my slave cylinder, my master cylinder was changed 2 years ago. Please help!
You need to check for oil fluid on the clutch master and slave cylinders. By this look at it and pull back the boot a seal could have gone bad which may have allowed air to get into the system.
