2G Pops (enrichment) button help
SAUBIK
5+ Year Contributor
211
186
Feb 27, 2020
Bratislava, Europe
Hi guys, I have an idea to make pops to switch I have left ready on my dash, but I have no idea if it is possible with stock ECU just with add some kind of obstacle, resistor, transistor etc what I can switch ON/OFF when I will need it.
If somebody tried similar thing (ideally successfully), let me know..
Or if you have an idea how it can be made, it helps me get the way
Thank you in advance :)
Huh?
I hope you're not talking about those baffoons who purposely have their tune screwed up to enrich on decel
or are you talking about rolling antilag which is enrichment and retarded timing
Something like what?
False enrichment can only occur with a stock ecu if you can fool the ecu into thinking there is more air than there actually is by jacking the MAF signal, which is basically how a safc works, but this only works in open loop.
So, short answer, no. Not with a resistor or even a transistor.
