420A Multiple Sensor DTC
Shibbi
Mar 11, 2020
Virginia beach, Virginia
96 gs 2.0 auto went to start it and it took awhile and runs really choppy I've got the following dtc
P0120
P0123
P0108
P0113
Feel like its possibly a ground issue any advice is much appreciated thanks.
120 is a TPS issue so check that it is plugged in good
123 is a TPS high sensor reading meaning the ECU saw it out of range above its highest value of 5v
108 is a MAF sensor reading to high also and
113 is the IAT Intake Air Temperature sending too high of a signal also.
Check all grounds and connections at those sensors, unhook the battery for 5 mins or so to clear the codes and then attempt to restart it.
Thought about the ECU also myself. The sensors are telling it a HIGH value which I hope hasn't burned a trace anywhere.
Glad you brought that up!
Or plugged in wrong since it is showing over voltage. Thanks Solomon for the tip!! :thumb:
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
