MMCD pressure readings..Oil etc..I'm lost
dmxsoulja3
71
Sep 4, 2004
Gulf Breeze/Pensacola, Florida
So I finally get the logger working correctly, and I'm lost, what type of system is the pressure readings in... my oil pressure is like .31 atm what exactly is that? is there anyway to change it to psi or bar, kpa? Thanks guys,
Josh :talon:
THANK YOU, what exactly does ATM stand for, atmospheric something I'm assuming?
not sure what it stands for, but its the SI unit for pressure. 1 atm is atmoshperic pressure at sea level I think.
Sounds like you using a version of MMCd from cbatters over on 3SI.
Most of the custom sensors on the 4th page are meaningless. You can go into the preferences and see what ECU memory locations those sensors are tied to if your interested but on a DSM the ECU doesn't an oil pressure sensor connected.
It's on my list of things to do to crosscheck what Clint added as defaults against the ECU code and also report the bug in 1.6g with flag0.
Steve
