Palm battery died -- lost Mmcd
91Bomb
908
7
Jul 15, 2003
US, New Jersey
I have a palm 515 with built in li-on battery but after letting it sit the battery died and I lost my Mmcd program. The palm has SD card slot so now I'm wondering if I could get the mmcd on SD card :confused:
Also I'm not that proficient with computers so can someone walk me through how to get mmcd back onto my palm or onto SD card if that's possible. Thanks
Download it here Download MMCd from SourceForge.net
To re-install it back on your Palm Device you will need the Palm Desktop Software. Once you have the Palm Desktop installed on your pc, you will need to start the application and add the mmcd.prc file to the Quick Install tool. You then plug your Palm Device to your PC either via DB9 port or USB and perform a Hotsynch with your Palm Desktop Application open. The program should do the rest. I would however recommend that you get a SDCard and install the mmcd application to that instead of the Palm Device. This will eliminate the need to re-install it again if the battery goes dead again.
