MMCd palm m100 question
Whitetalonb16g
370
Aug 4, 2003
Mahanoy City, Pennsylvania
Ok, so i got an Ebay cable for logging. Orginally I ordered it for a laptop, since my past posts of not having a serial port and it not working with a USB hookup. I have since bought a Palm OS m100. Well i got MMCd loaded up and seems to be installed correctly. Now I have a Serial hotsync cable that came with the m100 and it wouldn't connect to my Datalogger cable since both ends on the datalogger cable and hotsync cable were female DB9 ports.......
Fastforward to today, I ran to the local computer shop and bought a Male/Male DB9 Gender adapter. Now, here I am excited that it all might work, NOPE! it won't read.
What else do I need ? I read somewhere that I might need a (null modem adapter) ?
Anyone have insight or suggestions ?
Thanks
i have the same problem actually...i sent the seller an email and hopefully he will reply soon. I hope the problem is as easy as getting one of those null modem connectors. I saw them at radioshack where I bought the same male/male connector you did. Maybe i can take mine back to get the correct one
Shouldn't be a problem, radio shack is really good about letting you return things if they're the wrong part and you haven't destryed it, so should be as easy as walking in, saying this is the wrong piece, I need that one, and they'll swap it out, and you just pay the difference (or get it back if the null modem is cheaper)
i emailed the ebay seller and he said the cable was made for a PC and not a palm and that it wouldn't work...he said if i send the cable back and $5 he'll give me on for a palm. I think im going to try the other connector first (since im returning the current gender changer anyway) to make sure it won't work
Red91Tsi said:
sxevegan - is this the cable you are talking about?
Will this cable work with a 90 ECU?
thats not the one i got...although i wish i did. It looks better than mine.
Steven....from experience, do you think i can get mine to work with the null modem connecotr even though it was designed for a pc?
i bought the null modem connector and it works fine
next step is figuring out why i have 43 counts of knock at low throttle and 2*** rpm :thumb:
