Mix your own race gas... in the hard ware store
Status
Not open for further replies.
Well let me first sate the If your stupid try this . If your not stupid you have nothing to worry about. This is very dangrous, you can blow up your house, children, car, garage,washing machine,ect.
Im not to be held accountable for anything you do.
Things you will need.
5 gallons of 93 oct gas (you can use less and lower oct amounts but its less potent)
a big pot (like a vat or crock)
a garden hose
a gaint strainer
paint thinner
paint stripper
2 2.5 gal containers of 87 oct gas
cheese grater
plastic wrappers the come on single slices of cheese.
24oz of coragated card board
a wagon wheel
bunson burner
knowleged of the dangers of flamable liquids
10 gal container to store your race gas.
5 gallon air tight container
washing machine you can use for a day
Old hot water tank
16lbs of wood chips
600v 1.25 amp dual elelment fuses
cargo pants
clip board
small shovel
access to a 8ft platform
Well now that you have ALL the above mentioned you can get started.
Take the 93 oct gas and pour those 5 gallons into the 10 gal container.
Take these items:
a garden hose
a gaint strainer
paint thinner
paint stripper
cheese grater
a wagon wheel
bunson burner
Old hot water tank
16lbs of wood chips
cargo pants
clip board
small shovel
and put on a table in your kitchen or selected work area.
Fire up the bunson burner and start to heat up the cheese grater to a red glow.
Put the paint thinner into the vat. Also do the same with the stripper.
Once the cheese grater is heated up red let it cool back to room temp again. (set aside you will need it later)
Put on the cargo pants I mentioned above and gather the plastic wrappers from the single sliced cheeses.
Put those in the vat also and mix untill disolved.
Take the 5 gallon container and put it in the washing machine. Disconnect the water supply and let it cycle so it shakes up the mixture of thinner/stripper/plastic wrap into a liquid.
Done? Good.
take the one 2.5 gals of 87 oct and put it in the 10 gal container.
grab the 5 gal container out of the washing machine and set the cheese grater inside of it, Then lid isnt required so disgard it. Use the 24 oz of carb board on the grater, untill its all passed though the cheese grater once and its in the mixture you made in the washing machine.
Now you should have two containers as of now.
one 2.5 gallons of 87 oct left
one 10 gallon container with 5 gallons of 93 oct and 2.5 gallons of 87.
And the two together.
You now have 267 oct gas in your 10 gallon container.
(87oct + 93oct + 87 oct)
Its also still unleaded unless you didnt follow my instructions to the T.
Enjoy.
Hope this can be added to the VFAQ or sticky or something.
About 110, and if it wasn't denatured, you could get wasted off of it.
im very new to this topic
really good info im trying this on the weekend.
xylene has a higher octane rating so i would need to add less ?right .
to the current users of octane boosters is reaching for 100octane overkill or boosting the octane should be start adding (rocket fuel) slow ?
what is the formula for 1/2 a tank and for 1/4 of a tank to get to 100 octane on both xylene and toluene?
Status
