1G Misfire under boost.......troubleshooting questions
MikeGrant
Dec 27, 2015
Victoria, BC, Canada
Hey I have a couple quick questions about a misfire I have just started to get on my car under boost around 4000 rpm. After the misfire started I installed new ngk br8es plugs gapped .026 and installed new ngk wires. Neither made a difference.
I just tested my coil and wanted to double check I used the correct settings on my tester when I tested the coil
PRIMARY COIL (set at 200 ohms)
-pins 2,3 1.16 ohms
-pins 1,3 1.18 ohms
SECONDARY COIL (set at 20k ohms)
-coil 1,4 12.63
-coil 2,3 12.78
I have a datalog that I will attach and you can see the misfire at approx 115 second mark.
I also was told to check if the timing belt had skipped a tooth as it can also cause the same misfire system , is there any truth in this and does it happen that often?
Thanks Mike
I had a similar problem I had my plugs gaped to.025
so I tightened up the gap to .018 because I was blowing out the spark
ever sense I did that it ran good under boost
What PSI are you running
I am looking to run around 24 psi peak boost but I am misfiring at 20 psi. If I use half throttle or less it will rev out and runs great besides this problem
I am going to try and find a good coil and swap it and if the problem still persist I will try and tighten the plug gap u[
He's already on a cold plug, but tighten up the gap and how are your air fuel's when it misfires, do they still look ok not to lean?
Make sure that the plug wires are separated and that they are not grounding out on anything. My coil faced UP so my wires pointed at the hood and I had some misfire issues. I moved my coil packs and got the wires away from the hood and the misfire went away. Just some of my issues I have had.
