Misfire when building boost
4g63jojo
107
Dec 4, 2010
melmore, Ohio
Ok, while in any gear, as I gradually increase the throttle, as soon as my boost gauge climbs to ''0'' i start getting misfires and loud backfires. OMG If i try WOT boost will climb to my set 10psi and also miss and backfire. OMG Engine runs fine if I keep it in vacuum. :confused: ?!?!?!?!?!?!?!?!?! (stock 6bolt rebuild , 16g , walbro , 3inch turboback MBC set to 10psi)
Still makes sense to check it. New codes may present themselves without you even knowing, unless you check them on a constant basis. You can check it with an LED light, or buzzer from radio shack. There should be a few write ups on how its done.
I had similar problems before building boost. Found out that my boost controller tee to the bov was disconnected. I know your not suppose to do this but it eliminates flutter.
Today I did a boost leak test and unplugged the MAF to check the connections plugged it back in then started it up and let her get warm then went down the road and gave her a lil boostage and it was fine. Got going in third gear then WOT and ran perfect! :hellyeah: Thanks a lot every one for the help I appreciate it.
You may want to check that CEL, I eliminated all my emissions and it never threw a code, there is no sensors connected the the EGR or evap system so that would never throw a code. It's throwing codes for something else.
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
