mac 108
- 213
- 3
- Feb 15, 2005
Memphis,
Tennessee
Completely stock 1G turbo
Car developed a severe misfire and loss of power. Seems to be running on only two cylinders.
Plugs on cylinders 1 and 2 read fine. Plugs on cylinders 3 and 4 are black and gas soaked. While the car is idling, you can remove the plug wires on cylinder 3 or 4 and there will be no change in how it runs. Removing one of the plugs on cylinder 1 or 2 will cause the engine to die.
Stock heat range NGK plugs have less than 1000 miles on them. I have replaced the plug wires and tried 3 different coils. Compression is uniform across all cylinders at about 150 cold.
What's my next move? This car ran great then developed this problem out of the blue without warning.
